M998 Antenna mount
papakb
1,183
San Jose, Ca
With this style antenna mount you want to add a triangular backing plate inside the panel or the whipping of the antenna will tear it off of the truck. It's a part of the original antenna installation kit that often gets lost when they get removed from vehicles. Easy to make from 1/8" aluminum.
papakb
1,183
San Jose, Ca
Tom R, There's only 1 backup plate in the installation. Greg's picture showed one of the early and later style plates. In a pinch you could use large diameter washers (fender washers) but you'll want to double or triple them up to add rigidity to the bracket.
86humv
496
Texas
The one on the right will clear the rivets on the inside of the fender.
I tried them on left and right fenders with properly drilled mount holes.
I seen a few trucks out there that used the one on the left on outside, and other on the inside.
I had a few of each made...$ 10 ea. for plane one, $ 12 ea on right one plus shipping.
86humv
496
Texas
Getting a new batch of plates done to match 2 trucks, and 2 new fenders I have un drilled,
as original set fits some fenders , but other fenders might have one rivet in a different location requiring a mod.
Beaufort12
Germany
Hi,
Im looking for those mounts / brackets, left and right side.
Maybe someone knows the part numbers or the ordiginal part description, so that I can find them...or if you want to get rid of it.... pm me:grin:
