M998 Best Glow Plugs To Buy
WhoMe08721
123
Bayville/NJ
Hey Guys,
It's cold again here in New Jersey and as we all know the Hmmwv hates the cold and kicks like a mule on start up. My question today is what is the best glow plugs to buy and how often should one replace them with new one. I only get about (2) years on (Wellman Glow plugs) are these good plug???? Also I have tested the cold start advance solenoid with the instructions from the (Component Testing and Troubleshooting Manual) and it checks out good. But is there any thing I have have to do to make the cold start advance work????
mgFray
975
Southern Minnesota
Stay away from ebay. Go to MacMotors or Kascar (Real4wd) and buy the glow plugs.
When you get them (from any supplier) verify the hex is _NOT_ 10mm, if it is, send them back, they're counterfit. Counterfits fail and cause damage to the glow controller and/or get stuck in the engine!
Once you have the real thing, I would expect (depending on the amount of driving) around 2 years (maybe more) on a set of plugs before they will start to swell. Note, they'll still work for much longer, but the swelling is key. For about $8 a glow plug (x8), just replace them every few years before they get stuck in the engine or cause problems.
As for the system working, with good glow plugs and a modern start box (military or one of the aftermarket manual ones) my HMMWV started just fine at -20F, started within seconds.. (I did have to push the accelerator a bit for about 30 seconds to keep it running, but starting was not the problem!)
(I've got a 6.5L GEP, no turbo, in my rig...)
