Has a fording kit. Manual states a clogged vent filter will cause vacuum in tank/fuel problems. Thanks for suggestion on checking oil. Several important items are also attached to the main vent line.
Just found this on:
Hummer Trivia & Misc Info
Don't Modify the Air Intake System
Even AMG has not covered their air cleaner and gearbox vent system interrelated functions in HUMMER Manuals or as I recall not even during Tech training sessions, so I cannot hope to cover it properly here ..guess you could just trust me on this one!
BUT ..basically it all has to do with the orifice of vent tube, p/n 12340799. Just where it is located inside the air cleaner, how it is positioned relative to the direction of air flow, the velocity of air flowing by its orifice (venturi vacuum effect) that determines how well, if at all, the vent system functions. When too much vacuum was created it actually sucked diesel fuel into the air cleaner on the original HMMWV design. For that reason ever since there has been a separate fuel tank vent line run and it is always open to atmosphere ..never comes under a vacuum! If too little vacuum is created or
the reverse, incoming air pressurizes the vent system, guess you know what the results can be!
Now what?
