M998 Generator Gauge Not working
AynorArmory
Aynor, sc
I just got my grounding kit from Kascar and it works great. Since i have had the M998 my generator gauge has not worked. Thought maybe the grounding harness would fix that but nope. Any ideas? I replaced the gauge with a brand new one. Any thoughts?
mechanicjim
40
Chicago il
check the wires going into to see if system voltage is getting there, you can also see with your old gauge by looking up its wire schematic can just making jumper leads to a battery to see if it'll "work"
papakb
1,184
San Jose, Ca
Use a multimeter and read pins N (Alt Out) and P (Alt Gnd) on the STE/ICE connector. If you have voltage there the alternator is working. The ribbed connector on the voltmeter is the alternator input pin so look for + voltage there. The smooth connector on the voltmeter is the ground pin. Make sure it's connected to the ground stud behind the heater control panel. Not much else to this circuit. The voltmeters are common failure items.
