M998 no power at all, batteries good - help?
fuelme
michigan
Everything has been working just great, now no power at all. Charged and tested batteries, they are good. Lights do not work, wait light does not come on, totally dead. Any suggestions? Could a fuse do this, or maybe bad battery ground? Any suggestions would be appreciated. Or if anyone is in Detroit Michigan (SE MI) and wants to look at it I would be open to that too! Thanks!
gcbennet
Trenton, ON
Pull out your multi-meter and the troubleshooting guide in the TM and check all of the points starting at your batteries. I had a similar issue once which turned out to be a corroded pin in the engine harness cannon plug.
