m998 with parking brake upgrade
NVAM998
Virginia
New to me M998 with MWO 9-2320-280-35-1 parking brake upgrade. I read the MWO. I guess the adjustment is via the linkage from the handle. Is there a different procedure for this with the MWO applied? The brake doesn't really hold and I'm hoping it will if I snug it up a little but don't want it dragging. Or do the parking brakes just not work on these vehicles? Constantly choking the wheels is less than attractive.
Thanks for any help.
Retiredwarhorses
4,122
Brentwood, Calif
the adjustment is and has always been at the lever, regardless of the MWO or not, if it’s not stopping the truck, you probably need to adjust the take up on the clevis under the truck at the lever inside the rubber boot, remove the clevis pin and adjust accordingly
Milcommoguy
2,167
Rosamond, CA
If for some reason handle is at the end of travel on the lever (wound tight) back it off a bit so you will have good adjustment later. Find the center of the twisty adjustment on top of the lever (could be stuck, rusted or busted) before the course adjustment to the clevis underneath. Check that brakes fully release and after a few ratchet clicks... brakes are coming on hard. IMO ? Hows the brakes pads ?
Here's a little more help > https://hummer-hmmwv.tpub.com/TM-9-2320-387-24-1/css/TM-9-2320-387-24-1_1036.htm
move thru the pages for
more info.
