LostInTheWorld
- 6
- 18
- Central california
My wife and I made some nice new mud flaps for our LMTV. We tried to find good replacement flaps, but everything we found was either not the right size, or it was too expensive. Maybe others know a better replacement, but we opted to make a new set.
We ordered fiber reinforced exterior grade heavy duty conveyor belt material from McMaster Carr:
P/N: 6000K1
Materials: Styrene-butadiene Rubber (tire rubber)
Thickness: 0.270 in
Width: 24 in
Length: 6 ft
There is enough material in one strip of belt to make four flaps with some extra. The flaps ended up being about $27.5 each.
The material cuts fairly well with a sharp razor-blade for the straight cuts, but the rounded corners were easier on a band saw with a fine toothed blade. To cut the bolt holes though it, we just took a bit of 1/2" OD stainless steel tubing and put a sharp edge on it with a bench grinder and ran it in a hand drill. It cut very nice clean holes.
![cutting-mud-flaps-2.jpg cutting-mud-flaps-2.jpg](https://www.steelsoldiers.com/data/attachments/430/430868-b18caa7adb337aa069bdaaa898d5c242.jpg)
![cutting-mud-flaps-5.jpg cutting-mud-flaps-5.jpg](https://www.steelsoldiers.com/data/attachments/430/430869-82705281d23c3f71f489b2bb6968db71.jpg)
![cutting-mud-flaps-6.jpg cutting-mud-flaps-6.jpg](https://www.steelsoldiers.com/data/attachments/430/430870-6b9490d033dfe04993f8abf67d99055f.jpg)
![cutting-mud-flaps-7.jpg cutting-mud-flaps-7.jpg](https://www.steelsoldiers.com/data/attachments/430/430871-5eb88e1858c614cbac58f598746a98d7.jpg)
P/N: 6000K1
Thickness: 0.270 in
Width: 24 in
Length: 6 ft
