magic question m1009
Barrman
1,771
Giddings, Texas
Do you mean the fitting for the pressure hose leaving the pump or the adaptor it fits into that is screwed into the pump? A flare nut wrench or better yet, a flare nut crow foot socket/wrench end will work for both.
I would suggest figuring out where the leak is above it first, cleaning it all off and maybe putting new O-rings in there as well.
319cssb
221
Easley SC
I am sure the leak is from the fitting not being tight. I think it is a 5/8 nut but the question is how to get there. I have crow feet wrenches in my GMTK, but it's near impossible to get a wrench there.
Barrman
1,771
Giddings, Texas
I have had success with a crow foot, universal adapter and a long extension coming in from outside the manifold and closer to the master cylinder than the power steering pump.
nyoffroad
687
Rochester NY
I had that fitting leak on one of my trucks and thought it was the line, dug around and found a used line good enough to get me home and my son and I went to fix the truck. He crawled under and turned out the line was just loose, we bought a cheap set of wrenches and cut one real short and used that. We didn't think to take any crow foots with us and the auto parts store didn't have them.
cucvrus
10,428
Jonestown Pennsylvania
I would just simply remove the belts and possibly remove the pump from the brackets. I would thoroughly clean the area and reattach the pump. Make sure the fitting it tight and clocked in the correct position. That is what happens. They get the fitting tight and push the hose because the clocking in wrong for clearance when mounted and the nut gets loose. Good Luck. report back. I enjoy challenges like this.
319cssb
221
Easley SC
As much as i hate having to take the power steering pump off. I am going to do just that. I have to replace the water pump, so I will remedy this situation, i will also rebuild the alternator then. Mission creep, as they say.
cucvrus
10,428
I know you can do that. That is easy peasy stuff. Besides you know you want to tear into anyway. That is how I always am. I get into things I never dealt with before on a weekly basis. I do my research and look at parts break downs and tear into it. The mechanics what you to think it is rocket science when it is actually just a jig saw puzzle that requires getting very dirty and challenging the mind. You can do it. Report back. Remember the water pump requires removing the entire front timing cover so you will need to remove the PS pump anyway. Unless you know something I don't know. Good Luck. Make sure all the parts are clean and painted before reassembly.
