maintance start of ldt endgine
orrisd4
10
HoneyGrove Pa
Finishing up a frame off restoration of my deuce , looking for advice on rigging up a sort of half-a**ed wiring harness to start the old girl so as to check for leaks before putting the body on.
need to hook up the lifter pump and start er up , rigging up the lifter pump is easy enough. But the massive draw of the starter is giving me pause on how to turn the starter over.
When i cut the old rotten harness off i didn't look at the solenoid first. Can anyone give me a bit of advice on rigging this up?
rickdavis81
84
Rich Hill, MO
Hook your batteries up in series to get your 24vdc. Run a jumper pigtail to your lift pump. Hook your negative to the starter negative lug, then it looks like you can either hook the positive lead to terminal 2 of the starter solenoid and jump the solenoid or finish wiring the solenoid and use a push button momentary switch to activate the solenoid.
