Major Rear Axle Leak
renovate7
Florida
I just received this A2C. I changed the oil in all 3 diffs. and cleaned all the axle vents. I drove the truck about 100' to this spot to repaint it. I came out to find this leak. I had filled the diffs with 1.5 gallons which took it to the edge of the fill hole. I'm going to remove a quart or so to get it about 1/2" below the hole. I have new seals on order and going to pull it down and repack the bearings and put in the new seals. It wasn't noticibly leaking when I received it. Any thoughts on why such a big leak?
hoop
14
va
Maybe you should have done a little bit of research, the full mark is 2 knuckles. Which is about 1" below the hole.
DHennon
Orlando, Fl
Or it could have been leaking before you got it, and was too low to leak. My sense is too much oil.
zeisshensoldt
I don't think it's too much oil. I just redid all my seals on the front axle and filled it with 1.5 gallons of 80w90 and it doesn't leak. Probably a bad seal.
Clay James
Reno/NV
Vents. I replaced my seals and repacked the bearings a few times and the vents built up enough pressure to make them leak. I cleaned the vents out but it still leaked. They can even build up pressure just sitting there. I replaced all the vents with remote breather lines and no leaks so far, at least not related to vent issues.
73m819
319
gainesville, ga.
Thank You for posting this, some of us have been PREACHING this mod for years, besides the axle, the trans, xcase, M/C, and ANYTHING else that uses these vents, needs the vents done away with
renovate7
Florida
I cleaned all the vents when I repaced the oil. The truck hasn't moved 100' since doing this. The 1.5 gallons is what the book calls for and won't over flow the fill hole. I'm guessing I have a really bad seal and was also low on oil. I did have the right side of the truck jacked up and that may have put a lot of oil in this axle tube...My immediate problem is I have 3 of the bud nuts that won't come off. I have a 900ft/lb gun and it won't budge them. I think I'm going to take out a quart, or two, and drive this to a local truck center to get them to loosen the nuts. I ordered new seals today and should have them this week. I've done an extensive search and read all the threads and more importantly looked at all the pics. Haven't done one of these seals yet, a new learning opportunity presents itself.
DieselBob
13
Arnold Maryland
Not a hard job to do. Just take your time and remember everything is heavy and really hurts if you drop it on your foot.
Sounds like you need to get a geared lug wrench for just such an occasion.
mattg2448
Port Huron, Michigan
Just got done doing axle seals on my truck, it was a breeze! Make sure you have the appropriate tools, for instance a 8 point 3" axle socket, which i had to wait 3 days for it to come in on order. Other than that, its a 1.5 - 3 hour job!
Bought an inner axle seal from Saturn Surplus, and Cork key way seals from Memphis Equipment, everything worked out great until i needed the socket.
I should go through, remove all my vents, make them fording lines, and redo all my seals and gaskets.
TIGERFANS2
Topeka, Ks
1) Go outside, do not pass go, do not collect 200 bucks, take out the axle vent and replace with a barbed fitting. Westlake sells 'em as do others. Westlake also sells cork sheets.
Seriously, do this. (Ask me why I'm so adamant about this :x)
2) go to lowes, home depot, wherever, buy a 2X3 (4?) piece of 3/4" plywood, several pre-cut pieces of sched. 40, 1/2" pvc, take the duals off together
Seriously, do this.
Or not.
cbvet
20
Northwest (Knox) Indiana
Okay, regarding spindle nut socket:
I forgot that the spindle nut is octagonal, & yes has 8 "points".
But that is properly referred to as an "octagonal" socket.
Sockets properly called 8 point, are for square nuts.
