knattrass
- 1
- 0
- Clarkston, MI
Here we go.... picked the head up from the machine shop surfaced and baked clean-they even buffed the s/plugs. Here's my checklist for comments:
1. Head - will prime and paint original silver with hi temp engine paint.
2. Intake - will have baked clean and paint as well - no powder coat (thanks!)
3. Exh Man - no bake or p/c (yes?) - my flap is stuck-any ideas to free it?
4. Carb - off to Jim Wallace for rehab(like Britney)
5. Fuel Pump - off to Then/Now for rehab, plus sent a core back up. Since I am going with elec wipers, Sid has a pump only/no vac pump for me. Thinking selling rehabs.
6. Gaskets - off to NAPA for a complete engine set, or should I buy ala carte?
7. Copper Spray - for head gasket. Any magic for putting on?
8. Hi temp thread sealant - I know to seal the bottom couple of threads
9. Head bolts - some rusty, soaking them in phosphoric, should I paint them or leave bare?
10. Manuals -got manuals and will read up b/4 diving in. Got to go buy a torque wrench -did I tell you we've never done this b/4?
11. Block - got carbon. folks say use a wire brush cyl by cyl and cover the ones not being brushed. Any cleaners or magic lub to use, or is this a dry affair? figured we crank the engine to bring the cyl up and make sure the valves are shut. any other ideas?
12. Coolant - stop cock on left side appears plugged. Was going to coat hanger the port or pipe cleaner. Once I get the engine back, i figured a power flush is in order.
If you get time to reply to my rambling, I would appreciate it.
Thanks in advance - Keith
