Manual transmission in XM211 Hybrid ID Please
firefox
General
51
Berkeley CA
Hi All,
I am trying to id a transmission that was put on the GMC302 engine in my
XM211. This is a frankenstine settup to accomodate a M108 wrecker body.
I will try to attach photos to this post. The photos are being made with a $7.00
camera, so wish me luck.
1,808
Bruce, is it a 4 speed? Measure the case length if you can. Looks a little like a Muncie SM420 but not conclusive.
JasonS
144
Eastern SD
It is probably a clark 5 speed w/OD (same as CCKW). My M135 had one. I think that it was a common swap. Trouble is the low range is lost. I had a lever to engage the reverse overruning clutch in the transfer case. What does yours have?
firefox
General
51
Berkeley CA
Bassed on pictures I found on the web, it is not the Muncie 420.
The one characteristic that stands out is that on both sides there are pockets with
threaded bolt holes on either side of the pocket. If you were a giant, you could use the two pockets for hand holds when you removed the transmission. It looks like the pockets
were designed to mate with some kind of side mounts. If you look at the two surfaces on either
side of the stick housing, those are the tops of the pockets. See added pic.
