Johnnyriot77
- 0
- 0
- Venango, PA
I'm replacing my master cylinder and hydroboost in my 1986 m1009 I ordered a stock 86 k5 blazer master cylinder and hydroboost I haven't got the hydro boost yet but I got the master cylinder and it does fit the old hydroboost or look like the old master cylinder at all I've heard that you should order k30 parts but I've heard the civilian k5 blazer parts work too did I order the wrong part or did I get the wrong part. Also I'm redoing the whole brake system will stock k5 rotors pad drums and shoes work or do I need k30 parts cause I thought the k5 and the m1009 had the same 10 bolt axles
