Master cylinder Internal leak check
Tackettr
Edmond/OK
Anyone know the size of the plug that goes in the Master Cylinder when doing this test. TM just says remove adapter #11 and put in plug #13.
Also, what size socket is required for the the wheel bearings? I was thinking it was 3" but want to be for sure because I want to buy one at lunch.
Thanks for any info.
Kevin
1,177
3 inch and 8 sided is correct for the wheel bearing nuts. If you do a search ,there have been a few posts on sources for them and brand/part numbers too. Search for OTC
