Master cylinder replacement, 1987 m35a2c
Bill in pa
40
homer city pa
Hi.
This is Bill in pa.
Im finally replacing my master cylinder.
As I said I have a 1987 M35A2C.
Was a U.S.A.F. truck.
Has duel air paks
I ordered a new one based on what the truck is. Master Cylinder New.jpgMaster Cylinder New.jpgMaster Cylinder Old.jpg
Master Cylinder Old.jpgThe one my wife is holding is the new one.
The other is the one that's in there now.
What do I need to order?
Thanks for any help
rustystud
2,852
Woodinville, Washington
That new master cylinder you have there is not a "dual" master cylinder but a single one. A new "Dual" master cylinder will run you about $250.00 to $300.00 easy. That one you have is for all the single circuit brake systems used on all the Deuce's until the late 1980's "Air Force" dual brake circuit Deuce's came out.
Bill in pa
40
homer city pa
Thanks for the help.
I completely explained to the guy what I have.
1987 M35A2C.
duel air paks U.S.A.F. truck.
Thats what he sent.
WillWagner
2,675
Monrovia, Ca.
Rusty, I dunno, that is not a FE777 MC, the outlet(s) are on the side and not at the rear, (single line) like the others I have seen. Also lokoks like a plastic reservoir. Looks like two outlets. Where do those two lines go?
rustystud
2,852
Guess Rusty was referring to the new MC held in hands, not the one installed.
Definitely not the correct replacement part.
Yes.
Though after looking at the picture again, it appears to have two ports. Confusing. Need some better pictures of the new unit. For sure it is not a M35A2 Dual master cylinder though.
WillWagner
2,675
Monrovia, Ca.
Yeah, I was referring to the mounted pic. The replacement is the FE777 style. Sorry for the confusion.
bigmike
354
Dixon CA.
Sure looks like the one held in her hands is for the single circuit brake system. The old one still mounted to the truck is a dual circuit MC.
Bill in pa
40
homer city pa
there is a casting number on the mounter master cylinder.
2230600. Looks exactly like what in there.
If you look that number up there are 9 different ones.
Difference is the line out size.
I ordered one $126 with the parts guys discount.
Nomad1
Conway NH
I think the fact that master cylinder she is holding is upside down may be throwing some people. At any rate he should be able to get refund or exchange for right one. The supplier should be able to straighten this out let know how you make out.
Bill in pa
40
homer city pa
Well I Got the correct replacement Master Cylinder yesterday.
Ordered it from Boyce Equipment.
Put it in today.
Stops on a dime with 9 cents change.
No more pumping. Good firm pedal. Don't fade to the floor.Newmastercylinder.jpg
