Trudge
- 0
- 0
- ballston spa NY 12020
what do you think is the max safe limit for horse power i could push my motor to without blowing it to little bits?
Well, hate to say it but you shall stay confused. Some swear by them others swear at them. For what they were designed to do and when they were designed i say they are great, in modern term, eh, they are mediocre.
That would be the LDS-465-2 engine. They did all of those modifications so they could turn up the fuel for another 50HP over the unmodified LDT-465 engine.the -2 engine put into the M656/M757/M791 trucks used a 22% bigger oil pump for piston cooling and I believe larger injectors and turbo, made anywhere from 50-75 more hp.
The Turbo on these trucks doesn't have a bypass to control the boost pressure?The problem with raising the power in a deuce all comes down to the same issue: The engine has a 22 to 1 compression ratio.
If you up the fuel, you are going to up the exhaust volume. If you up the exhaust volume, you are going to up the turbo speed. If you up the turbo speed, you are going to up the turbo boost pressure. And if you up the turbo boost pressure, you are going to drastically up the pressure in the cylinders. Doubling the boost pressure doubles the cylinder pressure, which stresses the headbolts, the rods, and the head gaskets... among other things.
-Chuck
