MDK-2M trench-digging vehicle Located in Poland
rtk
436
Lockport N.Y.
Wow , what a piece of equipment ! smokes a BIT , bet no LS fuel there ! lots of batteries on running boards , and that thing has got some get up and go . What is with the people hanging off the sides , he must have one **** of a GRIP !! could use a semi-U blade , LOL , leave it to the Russians !
USSR
316
USSR
MDK-2 - Army vehicle designed for fragments of pits for shelter for equipment or personnel.
Created based on the AT-T. Entered service in 1962.
Weight - 27.3 tons Maximum speed - 36 km / х
Performance in hard grounds - 200 m ³ / h
Calculation - 2 people.
USSR
316
USSR
There are better machines)For example, MDK-3. Now in Russia is developing a new foundation pit machine.
bchauvette
12
Easley SC USA, 29640
Awesome!!! I find it interesting how some countries have a type of vehicle while others do not. Gun trucks, armored cars, rotary trenches etc. It appears the right door is armored which happens to be the burm side.
USSR
316
USSR
Just my country has a lot of experience of defensive wars (the last 500 years at war)))))) So we have and create such military engineering vehicles.
USSR
316
USSR
The USSR had developed a large number of unique machines for different types of troops.
IPR - engineering underwater reconnaissance. This tank can ride on the ground (which is quite natural for the tank), swimming (this is also nothing new - tanks "learned" to swim in the early twentieth century), and can move in the water column as a submarine, or go on the bottom of the pond...
1359689781_800px-IRM_in_Technical_museum_-_2.jpg1359689815_1Fk4h.jpg1359690042_iprrus05russianarms0an.jpg
USSR
316
USSR
Obstacle clearing vehicle IMR-3M based on tracked chassis of tank T-90
Appointment
furnished with a multipurpose attachment , and a mine dredger, type KMT-R3, fitted with an electromagnetic sensor. The vehicle is armed with a 12.7mm NSVT machine gun and is equipped with radio set R-165-50U. For internal communication, it is equipped with interphone system R-174. The IMR-3M obstacle.
Karl kostman
866
Fargo ND
Another model number I have seen this unit called is a BAT-21, to the best of my knowledge its based on a T-34 Chassis with essentially a truck cab mounted to it, most I have seen have just a tank towing assembly on the back and a dozer blade on the front, whenever I see one of these beasts they are smoking up a storm and all I can think of is a Mad Max movie, certainly an interesting vehicle non the less!
KK
iatractor
19
SE Iowa
Some interesting equipment. I'm impressed with how far those large trenchers throw the soil. Reminds me of the railroad rotary snowplows.
rtk
436
Lockport N.Y.
Yes indeed , they sure make a HOLE fast , but then again when you need a hole you need it FAST ! wonder how they work in rocky soil ? one thing for sure they all look HEAVY DUTY !
USSR
316
USSR
KK
The main objective of BAT-2 for create roads and highways in a combat zone. The cab is pressurized, radiation protection and other interesting stuff on it)))
http://www.youtube.com/watch?v=qP_V8EdSyhk
USSR
316
USSR
These machines are designed to work with soils 1-4 category.
Rocky soil - is 5 or higher.
USSR
316
USSR
The world's largest bulldozer
Bulldozer T-800 is designed to develop the most severe of frozen soils and rocks.
Length - 12.4 meters.
Height - 4.7 m. Weight - 106 tons.
Engine - "BelAZ" (820 hp.).
Tank capacity - 2.5 tons.
Speed ​​- 10.6 km / h (forward), 14 km / h (back).
http://www.youtube.com/watch?v=HvEXOgOX8rw
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Well I know what I'm buying if I get rich! A tank with a blade and a crane, I'm in love. The M88a2 are similar, but look like a shoebox on tracks.
Ozzytrucker
Australia
Hello USSR,
Ozzy trucker from Australia here.
I am fascinated by this large Russian-built T-800 dozer. It's in the Cat D11/ Komatsu D575 class, way ahead of its time, at the time. In fact, I've been attempting some research on it for a while and among the few pics I could find (very hard to find) I notice the track frames have no vertical oscillation like a conventional track-type tractor, proven by no support (obviously not needed) on the front idlers. So it appears to use a hull-type chassis (??) where the track frames are fixed, (actually maybe it does not have track frames, rather a tank-design hull) and suspension is provided by oscillation built into the bottom rollers somehow. (??). Could this machine and the frame/chassis be derived from a Russian tank, a T-80 or T-90 or larger for instance??.
I''d like to know more about the actual design of this machine if anyone knows about it.
Cheers
Ozzytrucker
