measurements of engine bay
boghog360
S.E.MI
Hello, I'm new to this site, And have a chance to get a deuce with out a motor or trans. The rest is there from the t-case out to the wheels.
I have a 7.3 ford diesel engine and all the trimmings, from what I have found it appears that it should power the truck. My question is will it fit?
I missed a chance on a running truck. Then this idea set into my brain.
anyone have the distance betwen the frame rails, and the distance from the firewall to the rad. support?
Thanks in advance, and if any body thinks it won't power the truck, or fit, please speak-up. :hop: :roll:
1,823
Physically it will fit. The main concern is the steering column. You may have to offset the engine to the right to obtain the clearance depending on where you put it. Not much can be done with moving the original steering gear except to replace it.
boghog360
S.E.MI
Its a powerstroke, Had it to put in an m-715 but too tight of a fit with the intercooler and AC cond. and the 4" down pipe. I need to find out if it will fit in a deuce. I have the chance to get one minus the engine and trans, would see about using the 1 ton 5 speed I have.
Any idea what the distance is from the fire wall to the radiator on the deuce?
