Mechanic wanted, then found: Diesel Heaven in MI
Daby
Michigan
I'm a newby here and just bought a M1010 this past fall. I've converted it to a work truck with shelves in the back. The fuel gauge wasn't working so I took it to a local "diesel" mechanic to fix it. They replaced the fuel sending unit, fuel gauge and fuel filter. After that it ran terrible and continued to get worse until I can't even drive it anymore. Of course they wouldn't take responsibility for it and said they didn't know what to do.
I live in Clinton Michigan near Ann Arbor. If anyone nearby could help me out I would really appreciate it. Looking for hire mechanic not just "a favor". Call text or message.
(231)629-0074
Dave
timgoebel
South Haven, Michigan
Dave,
If you can swing doing the trip, you might try Diesel Haven, here in South Haven, Michigan. They do great work, making sure they deal with your issue properly. All the reputable shops in the area refer work there, and these guys are booked about 3-4 weeks out, earning their reputation on every job! Call Cody or Travis at 269-214-8392 (will text you same, but wanted to get the word out there). Please tell them Tim Goebel with the 1986 OD green Army truck sent you.
Good luck!
Tim
timgoebel
(231)629-0074
Dave
This guy might still be a good one to know: https://www.steelsoldiers.com/threads/west-michigan-roll-call.97855/
Daby
Michigan
Dave,
Good luck!
Tim
Thanks Tim much appreciated!
Daby
Michigan
Dave,
Good luck!
Tim
I just got my truck back from Diesel Haven. They fixed it in a week and were very reasonably priced. Highly recommend! Thanks again Tim!
Daby
Michigan
So if you don't mind, how did they fix your problem with the truck not working properly.
The "mechanic" that worked on it for 2 1/2 months put two batteries that were different. So they replaced the batteries for two matching ones. The "mechanic" also zip tied the fuel line running to the fuel tank to close to the drive shaft causing it to run a hole in it so they fixed that. The "mechanic" also installed a bad fuel pump that wasn't even the right one. Diesel haven installed the correct one. They also replaced the glow plugs because they were shot from trying to start it. Also the "mechanic" charged me twice what diesel haven charged.
ezgn
1,040
Lake Elsinore Ca.
Go back to the shop that botched the job and get your money back now that you have proof that they ripped you off.
