Mechanical brake light switch
wilsonmotors
ennis,texas
I am rebuilding my brakes. I have heard about all the issues with the brake light switch going out and leaking. I was thinking about the air switch upgrade but didn't like the idea that it might leak to and lose air pressure. So I was thinking about a mechanical switch for the truck. I found a small mechanical switch from a m998 that will plug right into my new harnes. I was wondering if anyone has done something like this or has any other ideas for this. I think that this would be a way safer upgrade has there would be no chance of any fluid or air leaks just a loss of brake lights if the switch went.
Jeepsinker
452
Dry Creek, Louisiana
I have thought about it. I have the air switch and it doesn't leak but it takes a lot of pedal effort to get the brake lights to come on. Whatever you do, don't mount it to the pedal.
Jeepsinker
452
If he were to mount it to the pedal it would be dragging wires every time it moved. Most brake switches are not mounted to the pedal, they are mounted to a bracket by the pedal that allows the switch to decompress when the pedal moves away from it. Brake switches are normally open switches, that complete a circuit when the switch is released.
Floridianson
2,501
Interlachen Fl.
30 years for a switch to work and not leak a little is not that bad. Myself I would get a NOS pressure switch just like what was in there R&R and be done with it.
Jeepsinker
452
True enough, but in my case it would be nice to have a mechanical switch because I can actually come to a full stop at low speeds without ever having my brake lights come on. And I already installed a new pressure switch. No gunk or water in my lines. It just sucks.
HanksDeuce
242
Prairieville, LA
For my hydroboost brake setup I installed a brake pressure switch in the Ford master cylinder (bottom) port. It's normally the port for the cruise control kill switch.
The switch is NAPA part number ECH SL147. It is pretty much the only pressure switch for newer style master cylinders that is compatible with Dot 5 brake fluid. I'm told this switch comes on at a lower pressure than most switches. The switch is male 1/8" NPT. I needed a female/male adapter from Speedway Motors to convert to 3/8-24" for the bottom port.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Stoplight-Switch/_/R-ECHSL147_0475651800
Here's a link to Speedway Motors $7 universal mechanical brake light switch.
http://www.speedwaymotors.com/Universal-Mechanical-Brake-Light-Switch,1972.html
You could always run both switches in parallel. If the pressure switch craps out you have the mechanical as backup.
rustystud
2,815
Woodinville, Washington
Our busses us a 4 psi air switch for the brake lights. I bought one from a truck supplier for my rig. Now I'll just install it like the retrofit says and no problems !
Jeepsinker
452
Are the electrical connections the same, or is there splicing involved? You make it sound like it is plug and play... Please elaborate. Btw, I got a part number for that filter base today.
rustystud
2,815
The pressure switch is a standard 1/8" NPT thread with 2 threaded studs to connect to. Great news about the filter base ! My friend quit working at IHC so I no longer have a inside man there anymore :(
