Peacemaker
- 0
- 1
- Dayton, OH
I want to start off by saying thank you to everyone on this site. I purchased a M1009 seven months ago and so far I have been able to search this site or look in the TMs to solve the many issues I have had.
I am attempting to replace my leaking fuel pump. I have removed the passenger side alternator and bracket. The old fuel pump slide out easily and I removed the screws holding the fuel pump plate on. I planned on removing the plate to make it easier to reinstall the pump but I can't get the plate off. It acts like it has been welded in place and I can't find any way to pry it off.
Since the plate wouldn't come off I was going to try to replace it holding the push rod up with a hacksaw blade, but the push rod won't move. Once I removed the pump it slide down against the plate and I can't get it to budge. I tried spinning the motor using a wrench, it didn't help. As a last resort I quickly turned the key to for a second a few times since I have seen several people suggest that but it didn't help either.
Any suggestions would be greatly appreciated.
Thank You
Thank You
