coyote62ny
- -1
- 0
- sherburne new york
just bought my first mep-003 runs great puts out power but i think i might have trouble with the battery charging system i have looked through the manuals it has a lot about not charging but i think mine might be charging to much i installed new batteries the charge gauge starts out in the green after the engine starts but goes to the red above the green after about ten minutes run time i checked the voltage at the batteries it was at 30 volts could this be because the new ones are not fully charged ? i bought the generator running when i went to look at it we ran it for about 45minutes the person i got from had his batteries in the set the meter was in the green the whole time we had it running . my other question is the hertz gauge pegs below 55 hertz i read one post on here where some one had the wires on the gauge switched so i switched them and then it pegs above 65 hertz but the hand held volt meter i had hooked into the 120 outlets said 60 hertz so i put the wires back . i checked the wires before switching and they were hooked up right positive on the gauge to positive on the transducer all ac voltages check out good . this generator is in great shape no dents all the paint intact 965 hours on the meter with rusty screws my military collection started with the 1a08 and 2a016 engines well a man just cant stop collecting this stuff i have plans on using the mep-003 to run my house in a power outage which we get a lot of in new york in the winter any help would be greatly appreciated .
