metalworker393
- 24
- 18
- Jackson NJ
Hello all and how is every body? Okay,I need a little guidance with my 002 genset.
I came home from work today and wanted to change the oil in my genset before it got dark.I went outside to start the unit up and let it warm up and couldn't get the starter to engage.I am getting the selenoid to click and engage but the starter will not turn.
I then checked the starter wire connections,saw a little rust.I removed the starter cleaned the wire connections and put the starter back in.Still just the selenoid clicking.I jumped the starter and it turned the engine over.Made oil pressure too.Still would not start.
Is there a issue because the tank is only a 1/4 full?(I was going to fill it after I did the oil change)Is there a pressure switch that has to see fuel pressure from the electric pumps before the starter engages?One thing I did seem to notice was the electric pumps didn't slow down the clicking noise during priming.
I ran the unit about two weeks ago when I thought it would be good just to fire it up and run it.Started like normal.Now I see little smoke when I jumped the stater.
Any help would be appreciated,Thanks and a safe weekend to all.
metalworker393
metalworker393
