M
marvgarr
Guest
I have low output on my mep-002 the nob is missing from the recon switch so do not no what it is set on the highest voltage I get is 120v ac from l1 and l2 all other voltage on lugs are 56v ac no mater recon position voltage never higher then 120 the ac 120v receptacle has 56 v ac the unit is running at 60hz field voltage is low at 7v dc I get no 24v dc from the s1 switch when held to start if I get flashing voltage I think the unit will put out proper voltage the recon switch is working just low voltage any ideas?
