SpareParts
- 0
- 0
- Auburn/CA
I have acquired a MEP 002 which runs. Voltage dials up 220 VAC, 1800 rpm produces 60 HZ and the battery meter shows that it is charging.
I turned the main run switch to start and held it for 3 seconds to flash energize the field. Everything works and is warmed up so I throw the main breaker but get nothing. The four metal posts under the panel for wire attachments have 0 VAC, nothing. Does anyone have any suggestions?
