sewerzuk
- 9
- 18
- Seaside, OR
Picked up my first GL purchase last week after 96 DAYS of waiting for my EUC to be approved.
I bought a MEP-002 with 2053 hrs from Ft. Lewis for $410. Althought this is my first GL purchase, this was not my first MEP-002; I got one in a scrap lot from a local wildlife refuge that I repaired and sold. So, I was familiar with the machine and already had the associated TM's on hand.
I changed the oil on it, flushed the fuel system, hooked a pair of jumper cables up to my deuce, and turned the switch. No more than 2 seconds of cranking and she fired right up...and at idle the voltmeter was pegged high. At 60hz, it was producing 360V single phase. That's a little too much![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I did a little troubleshooting, and narrowed the problem down to the VR board. I was busy tagging the wires for removal, when I noticed that leads 13 and 14 were reversed...so I put them where they belonged, and sure enough the machine worked perfect. The board was dated about 6 years newer than the genset, so some mechanic must have replaced a bad board and got the wires crossed when installing the new one.
I have a gen inlet plug with a 200A transfer switch hardwired into my shop, so I plugged it in and powered my shop for about 4 hours. I ran it at almost 100% load for quite a while with no problems, and a few passes with my welder pushed it well above the 100% mark.
I'll post a video of it running a little later; it's a great little machine and it looks good on the bed of my deuce![Mr. Green :mrgreen: :mrgreen:](https://www.steelsoldiers.com/images/smilies/icon_mrgreen.gif)
