mep-002 voltage fluctuating/ hunting
jbk
livingston la.
the voltage on this 002 acts like its hunting going up and down from 108 to 130 volts. this gen. did this and then stoped, but today it started again. i read a few previous threads that says theirs a pot or something on the regulator board to adjust i dont see where nor could i find this procedure in the tm.
dalbmpek
dallas pa
voltage problem
open up your front control panel. check the circut boards sometimes a diode or resister is starting to burn out. if it is you should see scorch marks on the board at the problem . not always but in 85% of the time
