- 3,634
- 5,335
- 113
- MA
It appears there is another option for those of you who fight with this part. So while this part was not originally designed for this set, it does work on the machine to make your hertz meter work again! I have installed one on an 003A here today and it worked just fine. I was discussing doing this swap a few weeks ago with @jamawieb, and he actually confirmed it worked after our discussion. Was time for me to get around to doing it too. Next is an 002 here with the same issue.
The item in question can be found on the big auction site for a good price ($12.90) under the search phrase "New Technology Research Corp. TRC Frequency Transducer Control Converter 60 HZ " with free shipping.
Installed:
![20200822_145504.jpg 20200822_145504.jpg](https://www.steelsoldiers.com/data/attachments/564/564965-3b481dd9af33298cee66840047b960a4.jpg)
![20200822_145513.jpg 20200822_145513.jpg](https://www.steelsoldiers.com/data/attachments/564/564966-585f902fba66e78aafa18607d67cf4a2.jpg)
The holes don't line up exactly, so I opened each top mounting hole with a 1/4" drill bit, and was able to make them pull tight. It used only the top 2 mounts. You could drill 2 more, or leave as is. I am going to get small rubber plugs to fill the bottom (2) holes in the operator control cube..
Unit:
![5be4bbb35b425017714e37f2b77ff9521a6e8968-1.jpg 5be4bbb35b425017714e37f2b77ff9521a6e8968-1.jpg](https://www.steelsoldiers.com/data/attachments/564/564967-d8013d5a021db148d492dfa5284612a2.jpg)
![9fbda67df165f5d888c6db0c77f788d11c6e6f0b-1.jpg 9fbda67df165f5d888c6db0c77f788d11c6e6f0b-1.jpg](https://www.steelsoldiers.com/data/attachments/564/564968-3f0563e2558d0c7d74bfc95ecf78cfad.jpg)
![42dfdeb537fb1c88367fbf03c79946fb236d3e22-1.jpg 42dfdeb537fb1c88367fbf03c79946fb236d3e22-1.jpg](https://www.steelsoldiers.com/data/attachments/564/564969-c68fa5968b0579f00e83bc992ac0d5dc.jpg)
Installed:
Unit:
