Keith_J
- 1,316
- 113
- Schertz TX
Finally got my 002a home and started working on it. First was the fuel tank, once off, I saw the evidence of leaks. Sure enough, a line of pin holes in the bottom at the drain. The drain was concave in, making a trap for water that couldn't be drained.![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Oh well, plenty of rust busting training helping mk out on his M37. I pulled the fittings, filler-strainer and started working. The fitting bosses are pop riveted AND soldered. I used a long reach propane torch to flame it clean
? Not really, there were flames but nothing that didn't go out by itself. This lifted the CARC and let the solder flow out. Drill out the pop rivets and then pull the fitting bosses. Now full rust repair can happen, as in full scrubbing of the bottom through the filler opening (the strainer support rails prevent full access). Also, big rust gobs can flow out. I have the strainer soaking in TSP, then will pickle in phosphoric acid. The strainer is bronze, copper phosphate does not dissolve in water so it can soak in TSP or phosphoric acid safely.
Flaming also loosened the rust
. Looks like it is just the bottom. I can either cut back to the sound metal and weld in a flush patch (see mkcoen's M37 restoration thread for my abilities) or just solder the bottom solid. New metal is cheaper and faster.
I checked for water in the intake, no evidence. Engine turns over by hand (12" wrench) and no water in the oil. Just over-filled by 1/2". New air filter but nasty looking oil filter center gasket.
Been a busy morning, Took the air filter and control box off to work on the chipping paint and rust. While the phosphoric acid was working, i took the fuel filters off (bracket, all three) and pulled that service. All gaskets are shot and the fuel there smells really stake. The strainer is being cleaned by Pro Shot Copper Solvent IV. It looks new now.
The fuel tank is still waiting on major rust removal. I'll probably patch it with solder so the acid pickle job can go easier. The holes are small, just a dozen of them.
![CooKoo :cookoo: :cookoo:](https://www.steelsoldiers.com/images/smilies/cookoo.gif)
![Jumping :jumpin: :jumpin:](https://www.steelsoldiers.com/images/smilies/hop.gif)
