I have had this MEP-002A for a few years now. It has been in storage while I have been working on the road and has been started once a month or so. I finally bought a place here in East Texas and moved it down here from Oregon with me. We had a power outage last night for a few hours. I am able to start the unit and it seems to run just fine and 62 hz and puts out proper 240 voltage. When I put any load on the gen set past 25 percent, the HZ drops to around 58 hz and I have to go out and adjust it with the knob on the front.
Now today I wired in one heating element off an old water heater. One element is supposed to be 4500 watts at 240v. Generator was set to 62hz and when I turned the element on it dropped to 55 hz. Is this normal? or is it an excessive amount of droop? I also get zero black smoke when loaded down. When at 55 hz, I can manually go out and crank the knob to get proper 60 hz. The issue is when the load is removed it jumps to 65 and stays there.
My brother has a MEP-003a, and when we load it down with 12k watts it puffs black smoke for a split second and keeps on going like it isn't there. It just seems like the 002a maybe isn't able to get full throttle? Seems like at this moment it has very little surge capabilities. It has the ASK kit, and I haven't had a chance to pull the side off yet. Does this sound like a governor problem?
