RI MEP-002A / MEP-003A Spin on Fuel and oil filter adapters
Ray70
6,181
West greenwich/RI
Its been quite a while so I thought I should renew the classified for my spin on fuel filter adapters, referenced here:
And also to mention that I make spin on oil filter adapters for the 002/003 as well.
The oil filter adapter comes ready to install with the threaded fitting and a new square cut ring and will accept pretty much any oil filter with a 3/4-16 center thread.
I use WIX 1515 / NAPA Gold 51515 which is the equivalent to a Ford 302's PH-8A, Motorcraft FL-1A and dozens more.
All of my adapters are machined myself from solid 6061 aluminum. No crack prone die cast parts here.
The fuel filter bases are $120 each , the oil filters adapter kit is $100 and shipping is a flat rate $20 per order.
If interested, please contact me through the Private Message system.
