Ray70
- 5,862
- 113
- West greenwich/RI
Hello Everyone,
About a year or more ago I began machining a true drop-in fuel filter base to convert the Mep-002 through Mep-005 generators from canister to spin on filters.
Since then I have tried several times to locate my own post using the Google search function and have found that due to the way I titled it, even I have a very hard time finding it!
I have heard that other members searching for a spin-on solution are also unable to locate my original post, so I thought I should create a new post with a more appropriate , easier to search title and link it to the original post. Even as I write this I had difficulty finding the original post to copy the link!
Here is the link:
As a side note I also make oil filter adapters for the Mep-002A and Mep-003A
You can send a PM for more info, I will also update my ( Very old ) listing in the Classified section.
Here is the link:
Mep-002A 003A 004A 005A Drop in Spin on Fuel filter adapter
Last week I mentioned developing an easy to use spin-on fuel filter adapter for use rather than the the WIX 24470 Here is a look at the first production parts off the CNC machine and mounted on my 002A for your viewing pleasure. These adapters drop right in place of the original Fram canister...
www.steelsoldiers.com
