MEP-002A or 003A fuel fill strainer rust
1800 Diesel
26
Santa Rosa County, FL
Has anyone run across layers of rust on the brass screen inside the filler neck? I've used rust removal chemicals previously on all steel stuff, but for this application, am concerned the chemicals may eat away the brass screen. I'm wondering if there's a product that will remove the rust layer but not damage the brass screen. If not I will try my pressure washer (very carefully)....
Thanks,
Kevin
Isaac-1
51
SW, Louisiana
I had a lot of powdery scale build up and some rust on the screen on my MEP-003a filler, a short (15-20 minute) bath in a phosphoric acid / CLR solution removed most of the scale and left the brass screen downright shiny.
Ike
p.s. I would suggest checking frequently and not over doing it.
Munchies
Keesler Air force base/ MS
the coatings/plating on the strainer/strainer tube/ and strainer tube holder assembly in the tank are down right nasty. They build up some nasty stuff in the extreme humidity down here. If it is not rusting, it is white flakey growth, or green slime (not algae) that develops on those parts. Oxalic acid treatments work well for me and dont knock me over if I accidentally catch a sniff. Much more forgiving.... Oxalic acid crystals can be found on ebay
1800 Diesel
26
Ike
Ike,
Sounds like a good plan to use on all but the cleanest ones I get in. This one is the first time I've seen the rust buildup on the screen itself. CLR is a commercial product, right? Where did you get the phosphoric acid? And did you mixed the two at 50-50??
Thanks,
Kevin
1800 Diesel
26
I'll take a look at that stuff too. Would rather get something local if possible.
Thanks,
Kevin
Buttweet
Fort Valley Ga
I've found the tanks extremely difficult to clean so I replaced mine on all three gens with a 5 gal plastic container from Goo Goo car wash. They will give them to you for the asking. They are excellent for many uses. No rust.
uniquify
235
Sioux Falls, SD
Got any pictures of those plastic containers?
I picked up an 002 a couple months back. It's clean and complete on the outside, but the inside of the fuel tank is nasty. The filler neck, strainer, and bottom of the tank are covered in some white-ish crud that smells like varnish.
Buttweet
Fort Valley Ga
I'll get you a pic tomorrow. These are rather thick walled plastic containers, I threaded pipe threads thru the top for the 3 lines, kinda flimsy but good enough. Thx
