Boonies
- 34
- 18
- Reserve/New Mexico
I have spent many hours trying to adjust the governor. The manual says to adjust for maximum sensitivity without hunting. It says the speed should drop from 61.5 Hz no load to 60 Hz full load with no hunting. I am using a quality digital frequency meter, not the one the unit came with. The best droop I can achieve is 61.5 Hz to about 55-56 Hz. When I get this droop, it will hunt at no load. After adding approximately 1 kW load it will stop hunting. The hunting is not rapid like the manual says. It will run even for just about a second then act like it might die, but it dips and then revs back up where it was. Again, this happens about once per second. When I adjust the adjusting ratchet CW until the hunting goes away, the droop is 61.5 Hz no load down to about 53 Hz full load. I have had the generator 12 years and it has served us well. I never had any reason to measure the droop before, but I know it used to be much better, I just don't know how much. I don't know what the frequency used be over the full load range. I only know it is not good now.
The reason I titled this possible infector pump issues is because the injector pump has developed a leak. I am pretty sure it is where the rod that fuel arm that the governor linkage connects to goes into the pump. Unfortunately I can't remember if the governor issues started at the same time the leak started. Could such a leak in the injector pump cause the this problem? The leak is fairly small. If I clean the area up and run the engine, it takes about a minute before the first fuel drop drips off the bottom of the governor linkage. Then it will drip about one drop every 2 or 3 seconds.
I have read a few of threads on injector pump issues. Unfortunately, I have determined that I have the Bosh pump, not the Ambac.
I would greatly appreciate any help I can get with this. Thank You.
