n5yzv
- 0
- 6
- Boerne, TX
While I am waiting for my replacement switch (S1) I decided to test A1 "Diode" again. In the TM, It calls it K1. Whereas, it also calls it CR1. But it seems to be on A1. Hmm..A little confused. Ok, allot.
Anyway, in the control head, A1 is in the upper right side. Eight terminals. The procedure is to disconnect 3 - 8. Testing with an ohm meter, I should get high resistance (done in the right direction) between 5 & 6 and 7 & 8. Well, I get nothing.
So i pull the A1/K1/CR1 (pick) from the block. I think this is just a DPDT switch. Dunno why the manual calls it a Diode, but ok, whatever. I test it pin to pin, same results.
Am I testing this right? Also, when I look for the part online (M5757/23-003) it comes back with a $90 item. So is this the same thing I need to replace it with, or is there an alternative that is less expensive.
Thanks for the advice!
Mark
Mark
