Blake
- 60
- 28
- Opp, Alabama
I have a mep-003 and it will start up and run strong. After about 5 minutes it starts to not as run as strong and starts smoking pretty with very black heavy smoke. It will lose power and die shortly thereafter and wont restart. Its almost like it is burning up the engine oil. After is rest a while, it will usually start back up.
I didnt see how this engine breathes and initially thought it was pumping oil into the intake and burning that but didnt see any breather lines running to the intake.
The air does not seem to be restricted and does the same with no air filter in place.
I have replaced the injection pump with a rebuilt unit, flushed out the fuel tank, and installed all new filters. The engine is showing 400 hours and looks real good. It had been sitting for a while prior.
Do you have any ideas?
thanks!
thanks!
