MEP-003A CVT1 compatible with MEP-002A
RIrvin
Kirkwood MO
Expect several SS members have exchanged parts between MEP-002A and MEP-003A. I am aware there is a list of common parts. Unsure if anyone has swapped CT / CVT1 (transformers) successfully.The T M indicates NSNs are different but manufacturer's reference/part number are same for CVT!. The CT's appear to be the same. Would a 60Hz 10KW CVT1 work in 5KW (MEP-002A) output box without modification?
Korgoth1
radford, va
I would assume they are the same, on the 803-802 they are, only difference is the 802 is double the windings through the transformers...
