MEP 003a intake area wire harness needed
maddog
woodland hills Ca
Well I got the 2nd unit running with some stolen parts of my other unit. It doesn't make electricity yet, but I have decided to fix it and need a couple parts.
1. The wire harness complete with receptacle that mounts in the sheet metal at the intake manifold. It goes to the glow plugs and a few other things. I have the harness that goes to the sheet metal but nothing inside the sheet metal.
2. Throttle cable for setting the engine speed.
3. The non-metal cover over the split bolt electrical connections.
4. Battery hold down frame and bolts.
If anyone has this stuff I sure would like to buy it from you.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
If you can't find anybody who has the stuff, you can make a few of the things yourself. The cover over the connection box is just a piece of 1/4" fiberglass sheet, easy to cut and mount onto the"piano" hinge if you have the hinge...if not, you should be able to get the hinge at the hardware store.
The wiring to the glow plugs is also easy to get done yourself too, even without the connector that the main wiring harness screws into. If your wires are just cut, you can just determine which wires go to the glow plugs and to the intake heaters. The intake heaters are both in series...the hot wire for the intake heaters comes from the harness connector to the first heater element, then from the other side of the first element to the one terminal on the second heater element. The second terminal on the second element to ground. The hot wire going to the glow plugs just goes to each glow plug in parallel, and each glow plug is grounded.
I'm sure you would like it to be as much like it's supposed to be as you can get it. But if you can't find the stuff, then you do have the option to make some of it.
If money isn't an issue, Delks Army-Navy in NC has a lot of parts for these sets on hand.
maddog
woodland hills Ca
OK, you busted me. I have a fabrication shop and built electric vehicles for years. I was just being lazy.:p
Thanks for the Delks Army-Navy link. I will check them out.
mkcoen
381
Spring Branch, TX
It's located behind the gauge panel in the upper right hand corner. Eight lines going in, 4 per side. Here's a pic.
Pic didn't load. I'll switch to my other computer and try there.
