- 2,013
- 3,227
- 113
- Pepperell, Massachusetts
New design but no "mad new tech"Got to admit, these are parts I always kept on hand. They were show stoppers. If they die, the set will not run. Are they exactly the same as the old cards, or mad with newer tech?
I'll look into those too.I would be interested in these boards for MEP-002a.
Ray,Hi Kurt,
The hole pattern on the 002/003 A4 card is 2.660" wide and 2.600 high... not quite a square pattern.
The board itself is 3.5" wide and 3.0" high.
Genius!...., instead of opening the box, just find the 4 mounting nut/bolts on the outside and simply measure them from the outside.
OK, now I only need 1 measurement on the 004A A5 card. It's the hole center to hole center between either the right 2 mounting screws or the left two screws.
Could someone take an accurate measurement of it for me?
This...
Excellent, thank you!In case you haven't found out yet I measured 4.125"
