Timeline98
- 0
- 1
- Northern CT
I acquired a MEP-003A in a GL auction. This is what I found.
Hr Meter = 702
No Oil filter in the Oil Filter Housing.
No Fuel Filters in the primary or secondary Fuel Filter Housings (Strainer was there)
Water/Diesel in the Fuel Tank (rust on bottom of tank)
Greyish Oil in the Oil Pan.
Rust in the Air Cleaner housing (Air Filter present)
I proceeded to install a new oil filter, but stopped there. I figured I would try and remove the fan guard so I could see if the engine would turn over. No luck seized up. I removed all the air shrouds to more easily access the engine components. I removed the starter and tried turning the engine with a pry bar but not using excessive force. No luck. I then removed the intake manifold and dumped a 50/50 mix of ATF and Marvel Mystery Oil in each cylinder. I let this sit for about a week with still no luck rotating the crank.
Next I removed each of the injectors. Using a syringe with a piece of hose attached to the end,(children's medicine syringe), I extracted the fluids in each cylinder.
Now I am glad I didn't find any water in the cylinders. I then gave a good 15sec. spray of Kroil down each Cylinder via the Injector port. Four days have now passed, and I still can't rotate the engine. I am thinking I need to dump something in the crank case, but what should I use? (ATF, used motor oil, ??)
Do I simply have a toasted bottom end?
Any thoughts?
Thank You,
Keith![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
Hr Meter = 702
- Cyl #1 (Closest to the Blower Fan) I extracted the 50/50 mix I dumped down the intake,
- Cyl #2 - empty,
- Cyl #3, 50/50 mix,
- Cyl #4 - empty.
- Cyl #1 - empty,
- Cyl #2 50/50 mix,
- Cyl #3 - empty,
- Cyl #4 - 50/50 mix.
Any thoughts?
Thank You,
Keith
