- 20
- 0
- 0
- Pacifica, CA
I recently picked up a second MEP003A and prior to taking it up into the hills, I installed new filters, batteries, oil and fuel.
It fired right up and we test ran it for about an hour with a load of 15 amps on it. The unit functioned perfectly.
Now we brought it up to our cabin and after hooking everything up fired it up put a load on it and it was fine for about an hour. Then the engine began to stall and hesitate. I took the load off and the unit continued to do the same thing it would almost stall to the point the engine would die but catch itself and run back up to speed. Within a minute or so it would do it again, thinking it might be a fuel pressure issue I swapped out the fuel pumps from one unit to the other but the same problem. I even swapped out the filters still the same.
Any thoughts would be appreciated. I won't get a chance to play with it for a couple weeks but want to have a plan when we go back up.
Dennis
Dennis
