Jimc
- 9
- 18
- Mullica, nj
ok, i figured i would start a new thread on this. just to update, i picked up an 003 from someone privately selling. he managed to get the thing running but it didnt run well at all. i got to his place to pick it up, it was about 20 deg out and i saw him standing there with an ether can which made me cringe. he did get it running while i was there. tons of white smoke even after a warm up and after 5 min it shut down by itself. so the point i am at now.... i pulled the fuel tank. the fuel didnt really smell to fresh. i dumped the fuel out and it had some water and about 1/2 of mud in the bottom. i have that all clean up and i acid washed the inside so its nice and clean now. checked the facet pump strainers and surprising those were all clean. i pulled the factory fuel and water filters canisters out of it. those will be replaced with spin ons. the previous owner said he sent the injectors out to a company. they rebuilt 2 of them and clean and checked the other two. i am assuming at this point that the injectors are ok. i am a little nuts when it comes to stuff like this and usually go overboard on everything. i cant just try and get this running and then use it. i have to go through every part and piece on this thing and know everything is good to go so i continued to do a tear down on the fuel system and top end on the engine just to check the cylinder bores. especially since this other guy has done work to it which is sketchy at best and because he had that can of ether in his hand. here are some pics on where i am now.
cyl number 1, from gen end was a little wetter than the others. 2,3,4 were kinda dry. i am assuming thats probably from the ether. the bores are smooth. even some cross hatching still visible. there are some vertical lines in one spot on 2 & 3 but they are smooth. no scratches and i cant feel them with my fingernail. they almost seem more like a polished vertical line. anyone think thats a problem?
