Earl_Beverly
- 0
- 1
- Shepherd, Texas
Hi Guys,
When my generator first failed, it just slowed down to idle then died. Linkage to injector pump was holding to max throddle. I changed filters, vented air, and established fuel flow up to the injector pump.
The motor started and seemed to run fine (with no load).
Two weeks later when started and under load the set would not hold RPM. (it did run - injector gear not stripped?)
I checked all the usual suspects up to the pump again.
Next, when I pulled the cover and delivery valve from the injector and switched on the fuel pump there was full flow. I did not check fuel pressure,
I turned the engine over and held a probe against the plunger to check that it is moving. (Cam is ok?).
If anyone has a clue what I need to do or where I can get another pump, please let me know. Also, can a pump from a two cylindet MEP-002 be used,
Thanks,
Earl
Thanks,
Earl
