NJ MEP 004A 15kW Generator for sale- Upgraded digital controls!
MilgenXchange
new jersey
MEP 004A generator for sale. 15kW, 120/208- 277/480Vac. 11.9 hours on machine before upgrade. 14hrs currently.
Two hour, 100% load bank test was performed after control upgrade to confirm proper genset operation. Load bank report available w/ sale. Unit is in excellent condition and ready for years of reliable service. Trailer/ tires in very good condition. Trailer equipped with a pintle hitch and 4 pin lighting connector. The Mep 004a is a 12 lead generator and can be reconnected for 15kW single phase power.
Upgrades include:
- Comap Digital Genset Controller.
- Power-tronics XR8 Automatic Voltage Regulator
- Power-tronics AFM500X auto field flash module.
- New Current Transformers.
- New Engine coolant temperature, oil pressure and fuel level senders. New starter solenoid.
- New 120v 1500w Kim Hot Start Jacket water heater w/ new silicon hose and isolation valves.
- New Sens Microgenius 24vdc/5A battery charger.
- Remote start connections to tie into an automatic transfer switch.
- External Emergency stop switch.
- New engine coolant, oil and filters.
- All engine/ generator control wiring has been replaced w/ new. Sealed heat shrink connectors used throughout.
- New Exterior/ Interior Paint Job.
- New LED Trailer brake lights and wiring harness. All wiring connectors heat shrinked, harness wrapped w/ wire loom.
Can remove from trailer if requested. Local delivery may be available- please send a message with your address.
Located in New Jersey. Price is $6,500. Contact Milgenxchange@proton.me for more details.
Other low hour 10-100kW surplus units available with similar upgrades. PXL_20250523_180802622~2.jpgPXL_20250523_180727803~2.jpgPXL_20250523_180717165~2.jpgPXL_20250523_181827520.jpgPXL_20250523_181812650.jpgPXL_20250523_181757899.jpgPXL_20250523_181742217.jpgPXL_20250523_180745482~2.jpg
Disclaimer:
This generator has been upgraded with new electrical controls and is in good working condition. The buyer is welcome to witness the generator running under load (via a load bank test) at the time of sale.
Terms of Sale:
This generator is sold as-is, with no warranty expressed or implied.
The seller makes no guarantees regarding performance, reliability, or fitness for any specific application.
It is the sole responsibility of the buyer to ensure proper installation, usage, and maintenance of the generator.
The seller is not liable for any damage, loss, or injury resulting from the use or misuse of this equipment, including but not limited to damage to other equipment, property, or persons.
By purchasing this generator, the buyer acknowledges and accepts these terms.
