Rwf642
- 0
- 0
- Fox Island, Wa
I was investigating the reason for the dc circuit breaker not working on the front of the genset. I removed the cb without disconnecting the battery (really dumb move) it seems someone had wired all the wires to one terminal. (probably because the breaker is bad) none the less, I touched the ground to that terminal (I said it was dumb) sparks and now no power to panel which includes run/start/stop, panel lights test lights etc, etc. Where do I look for the problem? Is there a fuse or breaker or other fail safe? It looks like two of the wires go into a group going into a large distribution box, the other goes to the alternator. It still has 24 volts and is hot. The problem obviously goes into that big metal box. What can I expect if I open that thing up? Are there any fuses inside? Please help!!! Thanks for any insight.
