bill glaser
- 0
- 0
- Dyersburg, TN
I just purchased this generator and it wont start. No fuel was getting past the valve at the day tank. The float for the day tank was missing and tank dry. The guy I bought it from said it ran before he ran it out of fuel and didnt use the day tank. I took the day tank off and hooked the line off the fuel filter directly to the line that runs off the switch valve to the injector pump and removed the day tank and swit h valve. I took the line from the other filter that ran to the bottom of the day tank and ran that to the fuel tank as a return. Is this ok or do I have it backward? Do you have to use the day tank set up? I have fuel to the top of the injector pump but no fuel comes out the back of the IP to the injectors. What can be wrong? The lever on the side of the IP is wired tied like it should be. There is 24Vat theIP solenoid when cranked. Any help would be greatly appreciated.
