steelman101
- 7
- 3
- Georgia
I learned just how bad maintenance can be and the unit still run.
I started with the fuel pumps and went on to change the fuel filters. I got Wix filters.
When I went to install the gasket it was to large.
The one I removed was distorted as it appeared not quite right, when installed.
Can you point me in the right direction to acquire the right size.
Also look at the blue unit, it is not straight up. it abuts the fitting on the bottom.
The first filter canister is shorter. It appears that a replacement was installed on the final. Should it be changed?![Pictures of Generator 003.jpg Pictures of Generator 003.jpg](https://www.steelsoldiers.com/data/attachments/639/639300-04701ac5726e6ed010d66530c9576e74.jpg)
![Pictures of Generator 004.jpg Pictures of Generator 004.jpg](https://www.steelsoldiers.com/data/attachments/639/639304-acad7a3e67661824de6539b220a71a75.jpg)
