MEP-005a fill neck rubber hose
Anthill
Drexel Hill, PA
I have 2 MEP-005a's that the fill neck rubber hose has deteriorated so much that they leak when fueling. I am having a hard time finding a replacement for this , has anyone found anything that will work for this ?
Thanks,
Ant
DrillerSurplus
Salt Lake City. UT
Thanks,
Ant
I assume you are talking about the rubber sleeve that joins two metal fill tubes at about a 45 degree angle. We had the same problem on a 100kw genset and found a genuine replacement but it cost almost $300. As a temporary solution, we bought an inner tube for a motorcycle tire and made one.
