MEP 005a General Electronics Trouble
BenP
Paint Lick, KY USA
I have a MEP-005a that will not make power unless I jump the field with 24v. When I do that it will make power for a while then the HZ meter will max out and it will stop making power. I can jump the field and it will start making power again for a while, sometimes for an hour or two sometimes for just enough time for me to get back in the house and get my boots off. Also, the HZ adjustment is not working, I can turn the knob all the way either way without any change. The voltage adjustment knob works but not the voltage meter.
Any ideas?
Sincerely,
Ben
Guyfang
23,046
Burgkunstadt, Germany
Ben,
Unless you have a precise model, the hertz rheostat is not supposed to work. Use the black knob down below to adjust engine speed. Engine speed = Hertz.
Gen set excitation works like this. Push up the S1 start switch. The contacts in the S9 switch allow the set to start. Then when the engine reaches a certain RPM, the starter contacts kick out, and another set of S9 contacts close, allowing 24 volts to go to the Static exciter box.
Have you downloaded the TM's for this gen set?
