An 005A at 30KW is probably going to be too much generator for your house, 10KW (003A) is better suited for residential application. Just my .Can this generator be wired to provide a single-phase output using low zigzag? Looking at possibly purchasing one to provide backup power to the house.
Thanks,
Mike
Thank you for pointing me in the right directionFleebay
Search 5950-00-600-0840
INOVA says this will work it is a replacement for the T2 just wondering if it would workThank you for pointing me in the right direction
Cannot find the Video !!!!The answer is yes . The mel-004 and the 005 can be easily reconfigured on the voltage connection board for single phase operation. The instructions are posted on the board. You can also see the video by sewerzer on YouTube.
Look up sewerzuk on youtube. Lots of vids on generators.Cannot find the Video !!!!
MATT Verley Videos but No sewerzuk Videos Done that a long time ago !!!Look up sewerzuk on youtube. Lots of vids on generators.
OK That is the one I was using. Did not Know he had a ALIAS name. I have done the Change over on my 005A & it will not produce start up amps for my Air compressors. I had a video on here where I had my 10hp & 5 hp Air compressors running at the same time on 2 legs of 3 phase. I changed it over & TRIPPLE CHECKED EVERYTHING ON his video . It wll not run the 10 HP motor. It is like it is single phasing. Changed it back last night to 3 Phase & it is running everything in my truck shop . Pulling 61 amps on each of the 2 legs. This is just a Backup for the shop so I will not be using everything at once !!! Now to get the ADVR - 054 installed !!!Can this generator be wired to provide a single-phase output using low zigzag? Looking at possibly purchasing one to provide backup power to the house.
Thanks,
Mike
